Discussion topic: Wi-Fi is not working
Message posted on 18 Dec 2025 11:26 AM
Hi
My Wi-fi isn't working since last night.A red light is occurring on the router so please fix and resume it as soon as possible.I am facing very difficulty due to that.
I'm looking forward to hearing from you as soon as possible.
Message posted on 18 Dec 2025 11:32 AM
Re: Wi-Fi is not working
@Ganesh9
You aren’t contacting Sky here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ ** (it doesn’t necessarily disclose a problem immediately and there is up to an hours delay before the service checker picks up a lost connection so perhaps try it again later).**
