04 Jun 2022 12:17 AM
Hi,
im concerned my child is managing to get on over 18 sites using Wi-Fi. Is there a way of checking the search history.
04 Jun 2022 12:22 AM
Hi, @Jaderz.
You may not be able to view search history through Sky Broadband, but you can check in the device search history such as YouTube, Google etc. However, you can put an age restriction on viewable content 24/7 or at a set time which is logging into your MySky account via the Web or App and going into product settings, broadband and viewing age restriction?
04 Jun 2022 08:22 AM
Posted by a Superuser, not a Sky employee. Find out more@JaderzThe only way for you to be able to check is by going into the browsing history on the device in question.
