Discussion topic: Wi-Fi fault
This message was authored by: Darrenstace
Wi-Fi fault
My Wi-Fi not working
Re: Wi-Fi fault
@Darrenstace
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
Re: Wi-Fi fault
@Darrenstace Are you not seeing the sky Hub broadcast it's wifi name on your device! If it is not then try switching the hub off and see if a reset brings the wireless wi-fi signal back up!
