Discussion topic: Wi-Fi dropping out
Message posted on 31 Aug 2025 01:02 AM
Wi-Fi dropping out
Since changing to fibre my WiFi drops of every night. My security cameras loose signal each night. I wa on the internet tonight and it has dropped off again.
can you please check what the issue is
Message posted on 31 Aug 2025 04:55 AM
Re: Wi-Fi dropping out
@GVint
In case you’re not aware you aren’t contacting Sky Customer Services on here. This is a customer led discussion forum where Sky customers are available to try to help other customers.
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (Remember it doesn’t necessarily disclose a problem instantly and it takes a little while to update).
