Discussion topic: Wi-Fi do
Message posted on 08 Jul 2026 11:11 AM
Wi-Fi do
Hi,
I hope you are well.
Everything was working fine and out of nowhere the WiFi went down and it's not coming back on.
Message posted on 08 Jul 2026 11:15 AM
Re: Wi-Fi do
@Nicole148
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Message posted on 08 Jul 2026 11:19 AM
Re: Wi-Fi do
Thank you so much! I have tested it many times and it keeps saying that there are no issues. I will try again later and see if anything changes. I will also call them. Thank you so much!
