Discussion topic: Wi-Fi booster
Message posted on 18 Jul 2025 03:29 PM
Wi-Fi booster
Hi,
my house is really long and we have a hub and booster halfway down the house but my newly painted office is currently no use as the wifi can't extend. Can boost the booster and if so how?
I have searched for equipment and there are guides but no clear way how I can get equipment.
it's not newly extended it's just the room was my baby sons so never needed a connection there but he has moved rooms and I want to make it my office.
Message posted on 18 Jul 2025 03:39 PM
Re: Wi-Fi booster
@Loucaa23 If mainline max speed is not an issue, then would consider looking at powerline to do as you need!
Message posted on 18 Jul 2025 03:45 PM
Re: Wi-Fi booster
Do you know if they need to be on the same circuit. We have 3 phase power so I think they might be on different fuse boxes....
Message posted on 18 Jul 2025 03:56 PM - last edited: 18 Jul 2025 03:59 PM
Re: Wi-Fi booster
@Loucaa23 Different fuse, then NO chance of having powerline!
You would be better to have a look at a reasonable mesh wirless wi-fi system, they are not magic pills but do have a lot more horsepower, if not Ethenet cable point A to B, is that possible!
You may as well also say which Sky Hub you have currently and what booster you are using!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
