5
This discussion topic has been answered Discussion topic: Wi-Fi booster or extender
This message was authored by: SparkieRich
Hi.  I'm staying with my elderly MIL for a couple of days and looking to improve the WiFi coverage in her house. The sky router is a black box at one end of the house and there is no coverage at the other end which is where her bedroom is.
I'm looking for a simple solution.  Likely not a new mesh network.  Really just looking to extend the existing WiFi to cover the whole house.
This message was authored by: JimM1 Answer
Re: Wi-Fi booster or extender
@SparkieRich The link explains all about setting it up also, just sit it 1 foot away fron the SR203 hub, do the wps on each, button is on the RHS about 1 inch from the bottom, light on the middle will flash on each, takes about 5 minutes to connect the two devices, then all 3 green lights on the SE210 light up, NEXT IS IMPORTANT just leave it like that for 10 minutes. After disconnect move HALF way between the Hub and where you need the wireless, switch it on and get it all up to the three green light's again that takes about 3 min's boot time, see you have wi-fi now where you need it!
Avatar for SparkieRich
Thank you
Looks like she has a sky broadband hub.
@SparkieRich Then the Sky Broadband Booster is the one to get, you cannot from sky so third party or second hand, will be the easiest to set and match for operation so that has to be a Plus consideration factor!
Got one on Amazon. It arrives tomorrow which is great as I leave on Saturday. Thank you
