Discussion topic: Wi-Fi and internet down
This message was authored by: Grt
I have done all the checks … and your website says everything is fine. But it isn’t. My internet light is flickering orange and then no light. Help!!!!
Re: Wi-Fi and internet down
@Grt
Not our website. You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to assist other customers.
The first thing to do (even if you’ve already tried it), is use this link to check if there are any broadband outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst it's fine for customers working from home to use it, they won’t receive additional or quicker support.
