Discussion topic: Why dosent WPS work on my hub
Message posted on 21 Apr 2025 12:29 PM
I have a sky Max hub and it has been troublesome since I got it!
The security setting setting are too high for old tech and I have had to change them so it can connect. The latest problem is my HP print trying to connect it to the Internet. I tryed to uses the WPS button on the side of the router excepting it to turn amber to connect the printer but to no avail what is wrong with this router that it's a BIG Pain trying to connect to anything!
Message posted on 21 Apr 2025 12:30 PM - last edited: 21 Apr 2025 12:37 PM
Re: Why dosent WPS work on my hub
A Max Hub needs a short button press to trigger WPS, because some design genius decided that a long press on the same button is a hardware reset back to factory settings.
Message posted on 21 Apr 2025 01:00 PM
Thanks for the reply but it didn't work even with a short press of the button.
I give up
Message posted on 22 Dec 2025 04:44 PM
Did you get it to work? My Max hub WPS doesn't seem to do anything either. I've pressed it for more than 30 seconds which should reset it, but nothing happens. I can't connect the Sky Q boxes either and the boxes aren't accepting the WiFi if I put it in manually either.
Message posted on 22 Dec 2025 04:49 PM
@LR1984 & @red+rover theindication that the Sky Max hub is in wps listening mode is a blue flashing light just hold the WPS button in for 5 seconds. If it flashes green you have pressed too long and it is resetting itself.
Message posted on 22 Dec 2025 04:55 PM
@LR1984 see connecting to the max links for both!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Sky Max change settings link.
https://www.sky.com/help/articles/change-wifi-max-hub-settings-a
Message posted on 22 Dec 2025 05:04 PM
I only ever get a white light on the front, it doesn't change to blue or green. I'll keep trying though.
Message posted on 22 Dec 2025 05:08 PM
Thanks I've used the links already to try and connect the hub to the q boxes. The WPS isn't responding when I press it for either 5 seconds to connect to the q box, or even when pressing for over a minute. The light stays white, not blue or green.
Message posted on 22 Dec 2025 05:53 PM
@LR1984 Have a look at the wireless securities settings off the Max hub with your app, are you on wps3-t or wpa2-psk?
But will say that the factory reset not working in the 30+second time is very confusing!
Message posted on 22 Dec 2025 08:14 PM
@JimM1 looks like it says WPA3
Message posted on 22 Dec 2025 08:18 PM
@LR1984 Then expect the wps button to be disabled!
Message posted on 22 Dec 2025 08:21 PM
@JimM1 Oh! How do I change it? Or can't it be changed? I'm not very technical.
Message posted on 22 Dec 2025 08:39 PM - last edited: 22 Dec 2025 08:43 PM
@LR1984 Post number 6, 2nd link shows you what to do, and you need to do it through the MySky app on your mobile, in true WPA3 mode, then a WPS has no function whatsoever and is NOT allowed for working so that may be the case and the reason why you see it not blue light but the scary bit is why does it not reset on the 30sec+ hold in for a factory reset!
Your looking for Advanced settings and the WiFi security level, wpa2-psk would be advised to start with!
Message posted on 28 Sep 2026 10:18 PM
Did anyone have any luck, I have WPA3-T, WPA3, WPA2. Its set on WPA2 but the WPS button still doesn't function.
What setting should it be on to get the WPS button to light up?
Message posted on 29 Sep 2026 06:45 AM
@JSBB the WiFi security setting is irrelevant. I got my Sky Max hub into WPS mode by holding the WPS button in for 10 seconds then when released the LED flashed blue as it is designed to do.
Asxan aside when trying to connect Sky Q boxes only the main Q box can connect to these hubs. Any SkyQ mini boxes or Sky Q boosters have to be connected tomthe main Q box using WPS.
