This discussion topic has been answered Discussion topic: Which Hub?
Message posted on 13 Jun 2025 03:45 PM
I currently have a SR203 hub. Just switched to full fibre 150 and Sky have not sent me the newer SR213, they just sent an ethernet cable is this right? What should I have and i entitled to get this free?
Message posted on 13 Jun 2025 03:54 PM
Your current hub is the correct hub. You usually get the sr213 (stock permitting) on speeds of 500Mbps and above or subscribe to max max wall to wall wifi
Message posted on 13 Jun 2025 03:53 PM
Re: Which Hub?
@JamesBodie The Ethernet cable is correct and that is all you will get!
