Discussion topic: Whats a ubnt
This message was authored by anncaddy This message was authored by: anncaddy
Whats a ubnt
Whenever there an issue when I reconnect on phone to router there 2 like router that shows up, one my name one and another is ubnt, no clue what that is but it's only shows up when I reconnect whenever there is a Internet issue, when I click on ubnt it asks for a password to so I'm confused as to what it is, is it just my router being weird or something, any ideas
Re: Whats a ubnt
@anncaddy
It looks like a ubiquiti access point
Ubnt UniFi is an ecosystem of wireless access points, routers, switches, security cameras, controller devices, VoIP phones and access control products. It exists between businesses and cheap home network equipment. UniFi network equipment is managed by the UniFi network controller, which is a good middle ground, offering more flexibility and functions than AmpliFi. Using a typical UniFi network, you can select the required components and several of them.
This message was authored by Skull+Treaty This message was authored by: Skull+Treaty
Re: Whats a ubnt
Available here - What is Ubiquiti Networks UniFi?
"Sometimes, the only choices you have are bad ones, but you still have to choose"
