Discussion topic: What speeds would i get with sky wifi max connected via ethernet?
This message was authored by BigN This message was authored by: BigN
i was a bit drunk and brought it but oh well what speeds would i get with this router?
Re: What speeds would i get with sky wifi max connected via ethernet?
@BigN the Wifi Max hub has gigabit ethernet ports which can deliver up to 900Mb/s give or take the same as the SR203 router Sky provide as standard for their full fibre connections. Obviously you would need to buy a Gigabit service to get those speeds.
The improvement is in wifi speeds as the hub supports wifi 6 so with a device that also supports wifi6 you should get better wifi speeds assuming you are close enough to the hub. The SR203 tops out around 700Mb/s but in good conditiond you might get 900Mb/s out of a Wifi Max hub.
You have a 14 day cooling off period with your purchase.
