Discussion topic: What's going on with my WiFi? We have a booster, 7 devices connected still buffers.
This message was authored by Anonymous This message was authored by: Anonymous
Re: What's going on with my WiFi? We have a booster, 7 devices connected still buffers.
The stats do not show anything obvious as the connection looks quite good.  Depending on the layout and type of construction in your home you can often get wifi issues even with a booster.
There are a few ideas to consider
  • position the hub as near the centre of the house as possible, avoid having it low down or under other kit, ideally ir should be above radiators and furniture
  • the booster needs to receive a decent signal to be effective so position no more than halfway between the hub and where you need a boost
  • if your hone has solid internal walls or multiple floors you may need more tgan a free hub and one booster to get good wigi every where
