Discussion topic: Wfi out
This message was authored by: Kayhunter
Wfi out
Anyone else not got any WiFi in Dorset area
Re: Wfi out
@Kayhunter
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
Avatar for Kayhunter
Re: Wfi out
Thank u ive tried all that snd nothing is working broadband is red test js saying no outage and it should be working but its not
Re: Wfi out
@Kayhunter
For how long? Did you see this part of my post…
Re: Wfi out
@Kayhunter
What was the result of the line test:
