Discussion topic: Website slow to load on Safari and iPhone
This message was authored by SD0099 This message was authored by: SD0099
Some web sites are slow to load on Safari and my iphone but when Broadband Shield  is disabled it is fine. Google Chrome seems to be fine but I never use chrome on my Macbook. I want broadband shield set to PG but even Google is slow to load sometimes on Safari can anything be done to fix this. It must be an issue with Sky Broadband shield as Safari work fine outside the house on different WiFi.
This message was authored by Moixet This message was authored by: Moixet
Re: Website slow to load on Safari and iPhone
I had the same problem
Disable all LAN side IPv6 features on the router, works fine after that.
This message was authored by NickCuffe This message was authored by: NickCuffe
Hi, how do you do that?
