Discussion topic: Weak wifi
This message was authored by: Mulholland
Weak wifi
Hi
im having the same issue i had initially where some rooms have weak wifi.
can i get another wifi extender please
Re: Weak wifi
You will need to call Sky as you presumably did before as having more than one (three is the most you can have) will requite an engineer visit to set it up for you.
