Discussion topic: Weak wifi
Message posted on 13 Sep 2024 12:30 PM
Weak wifi
Hi,
My WiFi signal seems to be significantly weaker than it used to be. I used to be able to connect from every room in the house now I can only connect in the room where the router is. This means I'm usually on 5G and constantly using all of my data on my phone contract.
My phone provider are suggesting the best solution would be to switch to their WiFi, EE. I've been happy with Sky until now, can you offer a solution as I'd rather not go through the hassle of switching providers.
Thank you.
Message posted on 13 Sep 2024 02:11 PM
Re: Weak wifi
Hi @Debbie701
Have you gone through the WiFi troubleshooting?
