Discussion topic: Weak wifi signal
This message was authored by: MsCE
Weak wifi signal
The wifi keeps dropping both on mobile and laptop devices, especially in the second reception room/home office. It has been happening since we moved in but is an even bigger issue now during the summer holidays with increased usage. I upgraded when movinv and all tests are showinb strong signal but reality is very different
Re: Weak wifi signal
@MsCE  Is there a strong signal for Wi-Fi throughout the property or is weak in areas of the property.
Avatar for MsCE
It's intermittent in most areas, including the room where the router is so Sky Glass freezes regularly. Worst in the second reception room though. It's not even that big of a house!
@MsCE  What package did you upgrade to when you moved into your different property?
