Discussion topic: Weak wifi looking for a booster
This message was authored by: Weakwif1
We have very little / no connection of wifi in the upstairs of the house. We've brought a lan cable to try and help the problem however it hasn't really worked. We have a ps5 which is showing up as poor connection. Two phones both of which cannot connect at all to wifi upstairs. We are hoping for a booster to keep upstairs to help this issue.
Re: Weak wifi looking for a booster
@Weakwif1
Try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
