Discussion topic: Weak signal
This message was authored by: S_w
Weak signal
Hi have recently switched to sky and I'm having trouble with a weak signal in the dining room where I usually use computer and printer, is there anything that can be done for this problem. Everywhere else seems fine at the moment just the dining room.
Re: Weak signal
@S_w  what colour of router do you have from Sky? Black or white?
Avatar for S_w
Re: Weak signal
It's a black router
Re: Weak signal
@S_w Take a look at the link below, just not sure if you can get anymore from sky, but you would need a sky SE210 wireless wi-fi booster to get stronger wireless wi-fi or look to see if you can move your SR203 hub you have closer in the general direction towards where you work.
Either way getting a booster is an extra monthly cost from sky. The general from sky for a while was the SE210a variant that does not have an Ethernet port like the older SE210..... You could also consider Wireless/wired combined powerline if speed is not to great an issue.
Sky Broadband Boost | Sky Help | Sky.com | Sky Help | Sky.com
Avatar for S_w
Re: Weak signal
 Thanks for reply.Is there a booster that I can buy that would be compatible with the sky hub ?
