03 Jun 2024 12:37 AM
In my Iphone settings it says my wifi has weak security , why?
03 Jun 2024 05:43 AM - last edited: 03 Jun 2024 05:43 AM
Posted by a Superuser, not a Sky employee. Find out moreThis is an Apple issue so you will need to change the setting on your broadband router as per this information from them:
https://support.apple.com/en-gb/HT202068
03 Jun 2024 06:46 AM
Posted by a Superuser, not a Sky employee. Find out more@Dottydog Newer Apple devices support a new wifi security standard WPA3 and give this warning when connecting a network which doesn't offer that standard. By default the black Sky hubs use an older standard WPA2-PSK which is still secure. So if you have not changed the WiFi security settings on your Sky hub you can safely ignore that warning.
