Discussion topic: Weak security on phone
Message posted on 18 Aug 2024 08:23 PM
My phone says weak security. I've tried resetting my router but still the same. On iPhone 12 no updates available
Message posted on 18 Aug 2024 09:06 PM
Re: Weak security on phone
@Amandapanda123 iPhones complain if they are not connected to a service using WPA3 the problem is very few other devices can cope with WPA3 as their chips only support WPA2. The vast majority of routers including the black Sky hubs only offer WPA2 which is considered secure by the industry so unless you are a target of a state security service or similar I really wouldn't not worry. However the new white Wifi Max hub Sky have recently introduced support WPA3 then the only issue is replacing all of your other devices wiith new equipment thst supports WPA3 so your iPhone is happy.
