Discussion topic: Weak internet
Message posted on 17 Aug 2026 12:34 PM
Weak internet
My internet is playing up. If I have the tv on watching Netflix and want to use my laptop on the internet, everything slows down. Web pages take ages to load and the TV will tell me there are problems with the internet. What do I do? I need the internet for work.
Message posted on 17 Aug 2026 01:35 PM
Re: Weak internet
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
