7
This discussion topic has been answered Discussion topic: Weak/intermittent signal
This message was authored by: Sandra121
I've got WiFi max. Not that sure why it's better than  normal, but it was only a few quid extra, so just went and got it. I have this fluctuating WiFi signal, where the Internet seems speedy enough when it's working. But it's often not.  Yes, the problem room is the furthest one from the router. I get how the distance matters.  Trouble is, the provided network cable from this little unmovable openreach wall box to the router is only 6-8 feet long, so not much hope of trying it in a different room. Unless it's the hallway and I'm not trusting that with grandkids running around. I know a longer cable is a pretty sure fix, but they don't seem cheap.  That or a booster or some thing.
Don't I get some benefits from the WiFi max package to sort this out? Even if it's just a nice long cable. I'm sure they have those.. 😁
Re: Weak/intermittent signal
@Sandra121 Sky haveca 31 day cooling off period see https://www.sky.com/help/articles/cancel-sky-broadband
@Sandra121 the WiFi Max package allows for you to be lent up to 3 wifi extenders so call Sky and ask for one. If you need more than one they normally send an engineer out before sending those.
A longer cable from the openreach connection should not be expensive there are 2 possible types.  If the Openreach box has lights you require an ethernet cable but for a box without lights you need a DSL cable both cost around £10.for a 10m length.
Avatar for Sandra121
Thanks for the advice.  I now have a wi-fi extender I bought myself.  Yay for Amazon sunday deliveries.
Mixed feelings about it.  Everything works well now, so it's fine.  But I now clearly see why I was having trouble, whereas I didn't have that problem on V*rgin M*dia, ever.
It's that A) The routers are awful, or B) They're fine and I just got a bad one.
Unless I stand right next to the hub/router, it never shows full bars for connectivity.  On the other extreme, the wi-fi extender (working off of a SECONDHAND signal) blasts full bars to the end of my 60-foot garden.  The router itself had ZERO garden connectivity (I know it's not contracted to, but it highlights the difference in transmission strength) and the router had a dead zone in one bedroom which is now full bars off of the extender.
This is the very same signal the hub is putting out, of course.  So I think maybe someone needs to look at their transmitting methods and technology.  A £10 extender mass-produced in China sending a used signal 60 feet, plus about 15 feet of the house and through two walls can do it.
Isn't there some cooling off period?  My service started on March 1st.  Even though I've self-paid to fix my issue, I'm unimpressed how they've knowingly and in full knowledge mis-sold me a bad router with words and spiel that make it out to be the better and faster option, AND CHARGED EXTRA FOR IT.  Very underhand and sneaky and I don't like that.  It's like being conned in the street and voluntarily deciding you want to give them more money.   No, ta.
I looked at new Internet packages from other providers and, honestly, no-one's really offering anything better price-wise.  So now I got it working well through my (self-bought) extender, it'd be silly to leave just to prove a point.  And that point would only be to myself, as no massive corporation is going to notice or care much about any one individual leaving.  I guess this thread is concluded.
This message was authored by: JASONCAROL
Hi Sandra - which wifi extender did you get on Amazon as I'm having very weak signal as soon as I'm out the room where hub is.
Thanks!
Jason
@JASONCAROL as @Sandra121 has the sky Max hub, that is the white upright version and is linked below for you to see.
