Discussion topic: Weak WiFi signal
This message was authored by: TW33
Message posted on 13 Jul 2026 12:02 PM
Weak WiFi signal
Weak WiFi even though the signal appears to be good. Devices dropping signal and extremely slow
Find out more
Message posted on 13 Jul 2026 12:14 PM
Re: Weak WiFi signal
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
