Discussion topic: Weak Signal
Message posted on 18 Dec 2025 01:42 PM
Weak Signal
I have recently had SKY 150 broadband installed in my living room. When I'm connected to any device in the room (Laptop/mobile/tablet) the device shows 'weak signal' when connected to Wi-Fi. Please can somone adivse?
Message posted on 18 Dec 2025 02:03 PM
Re: Weak Signal
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 18 Dec 2025 10:43 PM
Re: Weak Signal
Thank you. 👍
