Discussion topic: We have to constantly reset
This message was authored by: JonK2
We upgraded to Sky Fibre and it's probably worse that before.!! We have to reset devices constantly and the signal strength is terrible.
Re: We have to constantly reset
@JonK2 if your hub has been moved which commonly happens when full fibre is installed that will cause the WiFi signal to change. In a few cases where customers have Skype Q and the switch to fibre came with a new white Sky hub the Q boxesxstop acting as WiFi extenders which also changes the WiFi signal.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
