Discussion topic: We have no Internet connection
Message posted on 28 Aug 2024 03:51 PM
Message posted on 28 Aug 2024 03:57 PM
Re: We have no Internet connection
@JackieMorris If you are only doing the service check that shows histroicak data, can you follow the latter part of the directions below please.
Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
