Discussion topic: Way
This message was authored by: justinway90
Way
I have had a new router at your suggestion. Ever since installing, my tv loses connection to my router every day requiring me to reset my network settings
Re: Way
@justinway90 you are not talking to Sky by posting in the forum you need to call them to get their help.
However poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
