17
Discussion topic: Want to report low download speed to hub. Service checker says speed is POOR.
This message was authored by MS820 This message was authored by: MS820
I have used the service checker to run a speed test it says speed is poor.
I am on a guaranteed speed of 23.1mbs and test result is 4.35mbs.
i want to report it as it has been that way for at least last 5 days.
This message was authored by cookiemonsteruk This message was authored by: cookiemonsteruk Answer
Re: Want to report low download speed to hub. Service checker says speed is POOR.
@MS820
The downstream noise margin looks fine. You would expect it the be much higher for an external fault but the 2nd line attenuation figure does suggest a fault.
If your guarantee is 23Mbps then the quickest way to sort out an engineer visit would be to call sky although we can also escalate this to sky
