Discussion topic: WIFI still not working
Message posted on 20 Nov 2025 06:42 PM
I still have no wifi although the test is saying I do. The Internet light on my hub is not on and I have no Internet access through my sky box neither can I connect to wifi
Message posted on 20 Nov 2025 06:46 PM
Re: WIFI still not working
@Emma522
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
