Discussion topic: WIFI outage
Message posted on 08 Jul 2026 07:15 AM
WIFI outage
There has been a WiFi outage in have not had WiFi since 3 yesterday could of been before as I was at work
app says there has been no outage
my 4G connection is absolutely shocking too
Message posted on 08 Jul 2026 07:32 AM
Re: WIFI outage
@Serenhorrocks
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
