Discussion topic: WIFI 6
This message was authored by 11Chris11 This message was authored by: 11Chris11
WIFI 6
WILL WIFI 6 BE SUPPORTED BY SKY??????????????
Locked
Re: WIFI 6
@11Chris11
You don't have to shout.
No UK ISP currently supplies a WiFi 6-capable router, and the ongoing worldwide semiconductor shortage suggests bringing out new mass-market models this year will be challenging when millions of units may be involved.  Current models cannot be upgraded through firmware updates: 802.11ax has a different hardware specification to 802.11ac
This message was authored by JPR007 This message was authored by: JPR007
Re: WIFI 6
@11Chris11 At the moment no. In future yes.
There are no timescales yet, for reasons as @TimmyBGood has stated.
Zen Superfast (FTTC), Fritzbox 7530, Sky Q 2TB UHD v3 (x1), Sky Q Mini (x2), Alienware Area 51-M, Panasonic TX-65HZ1000B, Denon AVR-X6300H, B&W CM8 S2, B&W CM1 S2 (x2), B&W CM Centre S2, REL S3 SHO (x2), Panasonic TX-P42G30B, Monitor Audio RS6, Marantz PM7001 KI, Denon HEOS 1 HS2 (x2), B&W P7, iPad Pro 12.9" (5th Gen), iPhone 14 Pro Max, iPad Mini 6 (work)
** No - I have nothing to do with Sky **
Re: WIFI 6
@11Chris11
In addition to @TimmyBGood even with a 3rd party wifi6 router you will need devices that support it especially wifi 6e.
Re: WIFI 6
https://www.ispreview.co.uk/index.php/2021/02/first-hints-of-future-wifi-6-bt-smarthub-3-broadband-r...
11Chris11
Re: WIFI 6
Any idea of timescales within Skys future plans??
Re: WIFI 6
Sky havent said anything, I would imagine its probably being worked on internally but likely not anything in the near future due to not many devices supporting WiFi 6 yet.
I am NOT a Sky Employee
Re: WIFI 6
All ISPs will be planning their next router to be specified to 802.11ax, as the article I linked to above indicates.  As Sky only released their last model two years ago they may not have one in a late stage of development at this time: the BT Smart Hub 2 is a year older, which is why it's assumed that their next model will arrive before anything from Sky.
This message was authored by Woody711 This message was authored by: Woody711
Re: WIFI 6
Jurassic Fibre provide a Nokia Wi-Fi 6 (AX) router. They are a UK based ISP offering full fibre  (FTTC).
I spoke with one of their installation engineers in Exeter, yesterday, 06.01.22 who confirmed this to be the case.
I believe that other full fibre Internet Service Providers also offer Wi-Fi 6 routers.
Re: WIFI 6
@Woody711
Yes they are niche suppliers with a few thousand to hundred thousand subscribers who likely expect more from their provider.
If you choose Sky or any other budget/mass market ISP for a matter of fact, as your broadband provider, you should not expect the latest technology
Re: WIFI 6
Sky, believe in better.
It should be......
Sky, believe in better, elsewhere  🤣
To be fair, Sky have been a decent ISP but their equipment is average at best.
Re: WIFI 6
To a very small number of addresses in a limited geographical area.  It's considerably quicker and easier for the emerging alternative full fibre providers to source a few thousand third-party WiFi 6 routers than for Sky, BT, Virgin and the like to specify, develop and commission their own-brand hardware which will be manufactured and distributed in the millions (and even more so during a global silicon component shortage): this is happening right now, but it takes time.
Re: WIFI 6
@TimmyBGood
That's right Timmy but other ISP's in different geographical areas also offer Wi-fi 6 routers here and now.
Some FTTP ISP's also offer monthly rolling contracts so that you can join them and rejoin a large ISP when they get around to installing FTTP in your area.
I appreciate that Sky and larger ISP's take years to roll new equipment out but the answer to the original post as to whether Sky offer Wi-fi 6 routers is no but other ISP's may well do in your area.
Locked
