Discussion topic: WI-FI
This message was authored by: Sandraszpilews
WI-FI
WI-FI not working turned it off and on and nothing won't be paying my bill unless you sort it out
Re: WI-FI
@Sandraszpilews
You can't withhold payment. Billing continues throughout any outage or fault.
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
