8
This discussion topic is read only This discussion topic has been answered Discussion topic: VoIP Router with FTTP Support
This message was authored by: Aurynfire
With my install date coming up in 11 days, I wanted to see if there are any good routers out there that support FTTP and VoIP that I can use other than the SR203 as I have always had problems with it and till now have been using a VR2800.  Any suggestion's on a good router that will be compatible with my new install, budget isnt so much of an issue...
Fantastically Autistic
Re: VoIP Router with FTTP Support
@Aurynfire
No-one has yet identified a non-Sky router which can support Sky Talk over VOIP: unless Sky choose to publish the configuration details required, I suspect this is unlikely to be possible as the Analogue Terminal Adapter (ATA) functionality is baked into the Hub.
Locked
@Aurynfire
A lot of routers support sky authentication mer /dhcp option 61/ dhcpv6 pd. So would need more info ie gaming , whole mesh etc,etc.  The sticking point is sky internet calls ie you need the sr203,  go for another voip serviceeg vonage or contact to see if openreach can be booked to carry out voice reinjection (bridge fibre over to the remants off the copper line)
@Aurynfire it depends what you mean by VOIP most any router will support third party VOIP services some like the Draytek range have specialistvsupport for telephony. However if you mean the Sky landline serviice bundled with the broadband then that will only operate via the Sky hub unfortunately.
@Aurynfire
If the ont hasn't been installed yet you can always politely ask the engineer about voice reinjection
@cookiemonsteruk dont think you can do that with Sky services but I would be happy to be proved wrong.
@Chrisee
It is listed on openreach website as premium install so may require a follow up and it has been suggested on here as a workround. But i'm just floating the idea 😁
@cookiemonsteruk no problem with ideas quite the opposite.
This issue is one that bugs me as use of a third party router seems to mean you lose the SkyTalk line with FTTP (and SOGEA orders including G.fast) and so far I have not seen any way round that but as I say I would like to be proved wrong. Many customers are quite happy with not having a voice line as third party VOIP solutions are available or just use their mobile but some are not - hence the warning.
Sky don't offer the option of a premium FTTP install even at the customer's expense unfortunately.
@Chrisee
Just vague memories off a customer very very politely asking for it on initial fttp install and engineer complied. Intriguing 🤫🤔
@Aurynfire
Locked
