Discussion topic: Virgin Media ftw
Message posted on 08 Aug 2025 05:49 AM
Virgin Media ftw
Sky are pathetic. Virgin media ftw! Even UW wasnt as bad a service as this
Message posted on 08 Aug 2025 07:17 AM - last edited: 08 Aug 2025 07:38 AM
Re: Virgin Media ftw
Have you a question?
edit: I see you posted on the outage thread in the Newport area overnight. If your broadband still isn’t working and you haven’t done it yet use this link to check to see if there are still any broadband problems or outages nearby.
Message posted on 08 Aug 2025 08:28 AM
I see you posted on the outage thread in the Newport area overnight. If your broadband still isn’t working and ""((you haven’t done it yet))"" use this link to check to see if there are still any broadband problems or outages nearby.
Ive done this atleast 4 times tonight. Sky is down in my area so nothing me or anyone else can do wont have any effect. Problem from Sky end.
Message posted on 08 Aug 2025 09:53 AM
@JessChilton highly unlikely an issue within Sky's network far more likely an issue in the Openreach connection which will get fixed how fast depends on what has failed or been damaged.
Sorry to break it to you but Virgin Media's netwok suffers occasional failures just like Openreach's.
