Discussion topic: Very poor wifi and losing connection constantly
This message was authored by: Mp46
Since we have had a new hub fitted outside our WiFi has been worse! Our phones are always losing wifi connection and films/tv programmes and constantly freezing and having to reset/turn off the box to reset
Re: Very poor wifi and losing connection constantly
@Mp46
A poor signal is something that can cause this so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account at about £6 per month then Sky will loan up to 3 pods as you can read about here:
The first one can be self installed while a second and third will require an engineer visit.
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
