Discussion topic: Very poor signal ipad
Message posted on 21 May 2025 03:22 PM
I mainly use my iPad upstairs but the WiFi signal keeps going. I never used to have this problem before upgrading. I also have WiFi booster.
Message posted on 21 May 2025 03:30 PM
Re: Very poor signal ipad
@LJ28 Just the iPad has issue, is it ok when down next to the main hub or have you not tried it there?
Message posted on 21 May 2025 03:39 PM
I've just bought it down to check and it keeps coming and going. All other devices which are connected to the WiFi say good iPad did say bad now nothing next to it.
Message posted on 21 May 2025 03:50 PM - last edited: 21 May 2025 03:52 PM
@LJ28 What hub do you have, white or black, how old is the iPad years wise, only asking the question as may have to fold back the WPA2-PSK mode if you have a white hub, and if so you need to do that via the app....
Also possible you may wish to look at the Broadband Shield settings on your account again since new hub may have put it back in operation. Can cause a lot off issues.
Message posted on 21 May 2025 04:30 PM
My hub is white. I upgraded to full fibre 75 with sky wifi max. Before I upgraded it worked fine.
my iPad is 10 generation which I purchased last year.
Thank you
Message posted on 21 May 2025 04:32 PM
@LJ28 Take a look at the Broadband Shield settings first!
