Discussion topic: Very Slow Broadband
This message was authored by: Ben+Holland
Very Slow Broadband
Hi
Just been on with the automated Broadband Sky help and it says I have a fault. Have run the tests and it says all "ok" yet my download speed is on 20mbs when I have Sky Gigafast. So this is not acceptable.
Please can someone investigate ASAP as this is causing issues as I am 100% home worker.
Feel free to call me.
thanks
Ben Holland
Re: Very Slow Broadband
@Ben+Holland
This is a customer ▶️ customer discussion forum where we try to help other customers. You haven’t actually contacted Sky by posting on here.
Sky won't / can't contact you based on your post. Your Community username isn't linked to any Sky accounts you may have, so no one knows who you are anyway.
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
