Discussion topic: Using Sky Q and Sky Max Pod
This message was authored by: Matthew+Sparks
I'm on full fibre and very delightful it is too.
I had an engineer pop over recently as some of the rooms weren't really getting great wireless connectivity. We also noted that our multi room set up had to be reconnected too.
The gentleman established that the Sky Broadband Booster wasn't compatible with my set up and I should instead solely be using the new Sky Max Pod. Fair enough. Fine with that.
However because of the connectivity and range within the house, he has recommended I use the Broadband Booster to make a bridge connection between the downstairs Sky Q box and the Mini, but that it should work entirely separate to the main WiFi setting.
He's kindly set that up for me and it appears to be working.
Can you offer me some guidance in case I need to make any changes to the wider set up?
It'll be easy enough to get the Max Pod connected to the Sky WiFi Max box. But how do I set up the bridge from Sky Q to the Mini, using the Booster Box, but ensuring that this doesn't interfere with the wider WiFi setup?
This message was authored by: Greenfingers001
Re: Using Sky Q and Sky Max Pod
Hi there @Matthew+Sparks , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
