Discussion topic: Users
Message posted on 29 Dec 2025 01:36 PM
Users
Is it possible for me to see who is signed in on my Wi-Fi?
Message posted on 29 Dec 2025 01:44 PM
Re: Users
@Gael depending on the hub you have you can see details of the devices connected but not who is using them. The white hubs show the details in the My Sky app. The black hubs have a list in the web interface at 192.168.0.1.
Message posted on 29 Dec 2025 01:46 PM - last edited: 29 Dec 2025 01:51 PM
Re: Users
@Gael At what level do you want to see, yes you can look to see what devices are attached to the sky Hub but then you need to know who and where the device belongs too.... If you have NOT given the password to anyone then there will be no connection if you hub is using said!
If you need also below, but you will have to do every device that you have connected!
Find, change or reset your WiFi password | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 29 Dec 2025 01:55 PM
Re: Users
Where can I find what devices are connected as I can't find anything on the app?
Message posted on 29 Dec 2025 01:59 PM - last edited: 29 Dec 2025 02:02 PM
Re: Users
@Gael Use a browser, and 192.168.0.1 should open up and list on the OLD Black sky Broadband hub, if you have the white sky Max Hub then you will be out off luck and need the app to show you!
The service checker may show you but you will have to expand the connected devices to see and if it works!
