Discussion topic: Use my old Q hub as extender?
This message was authored by: Abdnpete
Hi All,
Is it possible to use my old Sky Q hub as a wifi extendter,  with Amazon Eero Pro 6 tri-band?
And how is it done?
Thanks in advance
Re: Use my old Q hub as extender?
@Abdnpete Simply answer is NO.
This message was authored by: peter-marlow+1966
If you  have an a sky q hub they will  ask you to return  it to them as it is only on loan to you. You don't  actually  own it
P c marlow
Avatar for Abdnpete
I was told I don't have to return it in the email
@Abdnpete  Using 2 hubs would be extremely problematic even assuming you get them both to work, best to invest in network switches and access points if needed.  Both are relatively inexpensive and can give much greater flexibility for exepansion.
@peter-marlow+1966  I believ from some info that customers are not being asked to return Q hubs, most likely as they are being superseded by the newer hubs.
@peter-marlow+1966
Sky isn't necessarily insisting on Q Hubs being returned now: they are all obsolete by the end of next year anyway as they don't support Sky Talk Internet Calls, and so shouldn't be going out to new subscribers any more.
Avatar for Abdnpete
I was just not wanting to create E waste if possible.
@Abdnpete  You can still send it to recylce if you want to reduce waste.
