Discussion topic: Upgraded WiFi
This message was authored by: Charlienolan
Upgraded WiFi
I phoned to upgrade my WiFi and the person on the phone said should be done within 24 hours up to 900 mb/second but ive had a look online and its 270 mb/second and i was on 350mb/second but ive upgradeded to 900 and I nothing its happened and was told its 49£ a month and was aware there is a £10 one time charge but its saying its £90 and im not getting the service
Re: Upgraded WiFi
You've upgraded broadband (delivered over optical fibre and ethernet cable as far as the Hub)
Depending on the local wireless environment, WiFi speeds might show little difference.
