Discussion topic: Unstable network connection
Message posted on 26 Aug 2026 08:11 PM
Message posted on 27 Aug 2026 07:38 AM
Re: Unstable network connection
@Haroonkhan if using WiFi the most likely cause is poor WiFi coverage in yiur home. Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surface then the only answer is additional wifi sources.
