Discussion topic: Unstable Wifi
Message posted on 26 Jun 2025 08:08 PM
Unstable Wifi
We have moved to Sky Max and using a Sky Pod and Sky Boost. Our broadband speed has improved greatly but we are finding the WiFi coverage is unstable.
Message posted on 26 Jun 2025 08:19 PM
Re: Unstable Wifi
@WiFiStability What do you mean by unstable, do you also have other devices like sky Q or sky Mini's.
You may have to move the pod, and the sky booster to see what helps, if it is the hub that is poor nothing you can do about that!
Message posted on 26 Jun 2025 09:46 PM
Re: Unstable Wifi
WiFi signal dropppng out so devices are connecting then not connecting.
Message posted on 26 Jun 2025 09:51 PM
Re: Unstable Wifi
@WiFiStability What service are you on with the sky Max hub, Full Fibre or the FTTC copper OR Master socket connection.
Also what does the history look like for the last 30 day's with the service checker!
