29 Nov 2022 11:06 PM
We have been unable to connect to the internet since earlier today. I have tried all the trouble shooting methods several times and nothing is helping. The power and wifi lights on the hub are green but the voice and internet ones are not on. We are unable to connect to the internet and our phone is not working. Any ideas on what this could be?
Thank you.
30 Nov 2022 07:25 AM
Posted by a Superuser, not a Sky employee. Find out more@Jayne2468 if the internet light is not showing green your hub is not connected hence no service. Run the connection test in the My Sky app or website overca mobile connection as thst will tell you if there is a known issue affecting your service. If that does not give you an answer call Sky the lines are open from 7am and report the fault.
That is important as it will trigger Sky to contact Openreach whose network they use to check your line annd repair any faults. If your service os not back within 2 working days after you report the problem then you become elginle for compensation see Customer Auto-Compensation | Sky Help | Sky.com
