Discussion topic: Unable to connect to WiFi
This message was authored by: Tony1984
Message posted on 30 Jan 2026 07:25 PM
Hi, we have lost access to our WiFi, when entering our password is still doesn't connect and says check password... We haven't changed anything
Find out more
Message posted on 30 Jan 2026 07:30 PM
Re: Unable to connect to WiFi
If you are seeing an error about entering the wrong Wifi password then make sure you are not getting a 1 and l or a 0 and O muddled as it is quite easy to do this. It must also be entered as shown on the hub itself so use upper case letting if required.
