Discussion topic: Unable to connect my Epson printer
This message was authored by: Ade_G
Hi, unable to connect my Epson sx235 printer to the wifi in the normal way.
The printer can see the hub but won't connect
In the my sky app I cannot see the router to change the security setting to wpa2 as suggested in other threads
I've tried resetting the hub (its a new black one) and reinstalled the my sky app, still can't see the hub
Re: Unable to connect my Epson printer
@Ade_G Use the web interface to the hub, http ://192.168.0.1 to get you there take out the space between http and the colon!
Avatar for Ade_G
Thanks for that, when I look at the settings it's already showing it's wpa2-PSK
I'm at a loss now why it won't connect
Any suggestions
@Ade_G If it is not seeing a ssid or does it have a wps button to link the printer, you may just have to seperate the bands for the printer to be seen, the Tips above explains how to do that with your SR203 hub! WPS then printer and hub need to be next to each other!
Epson Stylus SX235W Support | Epson United Kingdom
Avatar for Ade_G
Thanks, sorry please explain 'separate the bands'
