Discussion topic: Ultrafast now much slower and dropouts several times an hour after working perfectly for a year
This message was authored by domelinho75 This message was authored by: domelinho75
Hi all,
I've had ultrafast almost a year. Was working perfectly, no issues until a few days ago. Now the average speeds have dramatically reduced and I get dropouts several times an hour, with buffering when content streamed through sky q and mini boxes and internet pages not loading for minutes at a time on other devices. I reset sky broadband hub and disconnected everything from network. Still getting same problems with just one device connected.
Network tests on sky site say there no issues with line/speeds to the hub and wifi analyser indicates strong signal until the dropouts. I'm wondering whether I have issue with the hub.
I've posted the stats.
Cheers
Re: Ultrafast now much slower and dropouts several times an hour after working perfectly for a year
Hi @domelinho75
When you reset the Sky hub did you hold the reset button for a minimum of 20 seconds as any shorter than that will only reboot it, not reset it.
I am NOT a Sky Employee
domelinho75
Hi,
Yes, I've reset it twice now. Problem seems to be getting worse. I've got one device connected via ethernet to the hub and even though all the lights on hub remain green, every minute I'm getting an internet disconnection message
@domelinho75
How is the device via ethernet connected? Directly to the hub or through some sort of booster? I ask because the router stats you posted show no devices connected via ethernet or any ethernet activity.
