Discussion topic: Tv signal dropping out
Message posted on 19 May 2025 05:22 PM
Internet signal keeps cutting out internttently
Message posted on 19 May 2025 05:36 PM
Re: Tv signal dropping out
@MichaelBentham black or white router from Sky?
Message posted on 19 May 2025 06:31 PM
How is your tv connected to the Internet, if possible an ethernet cable connection is more stable than WiFi, also the more devices that you have connected to the Internet the weaker the signal is to each one plus if you live in an old house and the interior walls are solid brick this can effect your wifi signal to, what is you broadband speed to your router
What speed is your tv getting
You can do two checks on your broadband first go to the my sky app and click on the broadband and run a check, this will tell what speed you are getting and if there are any issues in your area also if you have Netflix open the app go to get help click on that and go to check my network and run that, that will tell you what speed your tv is getting from your broadband
